Re: 1st test results
Aggie97,
You are ABSOLUTELY correct. Time and again, I see those results being "corrected" when there was no error.
For new users, it is easy (almost likely) to assume that you should post values for both the FAS/DPD and OTO tests.....which is exactly what you did.
After a while, we all figure out that they are seperate tests for different reasons.
Aggie, most of us simply post the results for the FC and CC (from the FAS/DPD test) and let everyone do their own math. However, I knew exactly what you meant and it happens on this forum so frequently it should be apparent to all of us.
