Don,
You will have little success unless you get a drops based test kit and can test your water several times during the day. With that very high CYA level of 100, you need to put enough Cl in there to bring it to 25ppm and KEEP IT THERE until your water clears. As long as your water is green, you're not keeping your CL high enough.
Dave S.
) there are 3 types of chlorine that needs to be measured:
