Results 1 to 10 of 27
Thread: Short Cycling
    Default Re: Kill the algae FIRST, if you have a DE Filter!!
    Quote Originally Posted by expose
    1)What do you do if you don't know what the CYA levels were when the pool was closed?
    Don't worry about it and get your CYA level correct. (See second answer for what will happen if your CYA was biodegaded.)
    2}What would be the effects of having "all the chemical residue from bio-degraded CYA?"
    You would have a lot of ammonia compounds and urea in the water and your chlorine levels won't hold. You will also have a lot of combined chlorine.
    3)How much chlorine would you add, and for how long after the water is clear?
    You would add enough chlorine to bring it to shock level for the amount of CYA CURRENTLY in your pool (see this thread http://www.poolforum.com/pf2/showthread.php?t=365 )
    and KEEP IT THERE until the Combine Chlorine is 0 ppm and your FC is holding. This might take a while and a LOT of chlorine!
    Hope this helps.
    Default Re: Short Cycling
    Back to my original problem of clogged DE filter. I finally went out to undo the 15 bolts in my DE filter, and hose down the fingers. The DE was sooooo gummed up - it was like putty. I don't know what got into the filter to make it that clogged up, but it took a hose spayer on full force to get it out. I only added shock (for conveinience factor), bleach, and ph+. The algae was still active when I started the filter, so maybe I should have really shocked before using the filter to filter out the dead stuff.
    Now I can re-add DE the normal way by draining to waste periodically, and the pressure is back to my pool's normal. I can do the normal to clear up the pool - add bleach to shock levels, vacuum, retest, repeat. WHen the pool is clear, I'll open the filter up again and clean it again for the season.
    It does filter much faster with the filter than with my Aquabot I can almost see the bottom of the deep end. We've gotten so much rain this week (about 7 inches here, but lots more in other parts of NE) it has been hard to get the pool work in.
    -betty
