Thread: Conversion - Baquacil to Chlorine - Disaster!!!!
    bcb1 is offline ** No working email address ** bcb1 0
    Default Re: Conversion - Baquacil to Chlorine - Disaster!!!!
    What you are experiencing is not unusual. It's normal to get a brownish/yellowish mess when you're doing the conversion. Like the previous poster, I have a sand filter, so I just replaced my sand after the conversion. Not sure if you will need to replace the screen or any of the "innards" of your DE filter or not...?
    Basically, you started by doing the right thing: shocking the pool with several pounds of cal hypo. You need to keep doing the same thing, either with cal hypo or with plain old bleach. Bring up your FC level to about 10-15ppm and try to keep it there. Baquacil eats up chlorine during the conversion, so you'll need to add it for the several days of your conversion process.
    With a sand filter, you have to backwash once or twice a day during the conversion. With a DE filter, since they filter much smaller particles than a sand filter, you might have to clean your filter as much as 4-5 times a day, I'm guessing.
    Don't give up! Freedom from Baquacrap is just around the corner. Just keep adding cal hypo (or bleach) and keep your FC level at 10-15 ppm for the next several days, and keep backwashing your filter.
    Your pool will go from yucky brown/yellow to lighter yellow to a sort of clear mountain dew color to crystal clear. And it ~should~ only take 3-4 days unless you had super-high levels of Bacqucil when you started.
    Good luck, post if you have any ??
    mbar's Avatar
    Ashland, PA
    I would check the calcium level in the water - if you are pouring in a lot of cal hypo, and your calcium is high you will get some calcium precipitating out of the water. Therefore I would use just plain laundry bleach. You must take it up to shock which will be 10 ppm without any cya in your water, which would be 4 1/2 gal of 6% bleach. You have to test often and add enough to get your level back to 10 - the more consistant you are, the faster your water will clear. You can also vacuum to waste - this will get out a bunch of the gook before it hits the filter - plus you will be adding back nice clean water. Brush the sides - skim off as much as you can of the gunk, and bleach, bleach, bleach!! Good luck, you will be very happy you did it!
    Northeast PA
  1. Baquacil to Chlorine conversion
    By telesforos in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 06-16-2012, 08:51 PM
  2. Baquacil CDX to Chlorine conversion
    By gbwarrior in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 02-07-2012, 03:59 PM
  3. Baquacil Conversion to Chlorine
    By texashornsbys in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 07-25-2006, 11:42 PM
  4. New - Need your help w/my baquacil to chlorine conversion
    By dacslow in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 05-29-2006, 03:53 PM
  5. Baquacil to Chlorine Conversion
    By godstreasures1 in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 04-20-2006, 11:09 AM
