Thread: Question on Walmart test kit
    no1ford is offline ** No working email address ** Thread Analyst no1ford 0
    Default Question on Walmart test kit
    I have a Walmart drop test kit and I was just double checking on how to read it. It has a Chlorine and a Bromine side in the same tube, and if I only look at the chlorine side it goes up to 5ppm (same box Bromine 10).
    I have a CYA of 30 so I know I need to keep my chlorine between 3 and 6ppm. I just want to make sure I am reading it correctly.
    So basciailly I am looking for someone who has the kit or knows about it and when they say 3-6ppm they mean the chlorine only side not 3-6 ppm because that is what it says in the one little box on tube 3 chlorine 6 bromine.
    I hope this makes sense, please let me know if it doesn't and I can try to re-write. I just want to make sure I am keeping my chlorine up so I have no more problems.
    Default Re: Question on Walmart test kit
    Ignore the bromine side, and just read your chlorine scale. Some people with spas use bromine for sanitation, and that's the only time you need to pay attention to that scale. YOur pool doesn't contain bromine--
    So The Walmart Test Truly Only Goes Up To 5ppm, Correct?
    CToon is offline Registered+ Thread Analyst CToon 0
    Elkins Park,Pa
    Yup , it only goes to 5...but you can still use it with your pool .
    The important thing is knowing where you're at and how much bleach you need to use. For example , lets say your at 3 ppm , if you add enough bleach to go up 2ppm , get you to 5.. if you are at 4 , going up 2 would put you at 6.. over the limit of the kit , but using educated guess , you'd know its there
    I couldnt even begin to do any of that without MWsmiths Bleach Calculator . if you dont already have it ...
    http://home.earthlink.net/%7Emwsmith...achCalc262.exe
    Thanks and to think all this time I thought my chlorine was high enough! No wonder I was having problems.
    I may seem super dense although I cannot figure out the bleach calc. It is in litres! I have an 18 x 48 pool with a cya of 30. I just dump an educated guess in every night! It would be great to actually have an exact amount. Can anyone help?
    Elkins Park,Pa
    In the upper left corner , click on More Calcs , go to settings , you can put in the values for pool volume and bleach stength , click imperial (u.s. gallons) , save & close..
