Thread: Can I bypass filter just to get the water circulating
    Default Re: Can I bypass filter just to get the water circulating
    My pump/filter has that option on there so I assume that it is OK to do so. I'm not sure why you would want to bypass the filter?
    Kansas
    Read the *Sticky* right above this post and you will see that Ben says its ok.
    ~Hoffmans
    rnjng Guest
    need to bypass filter cause it is in bad shape, the valve clamp is broken. I need to make sure that it is ok, to try to circulate the water with bb w/o filter to try to get the levels up. Where is the sticky???
    Northern Kentucky
    first post under spring start-up... halfway down #1
    rnjng Guest
    My filter does not have a recirculate setting, and it's broken anyway. Can I just connect the pump to the pool W/O the filter???
    Northern Kentucky
    I think the point made by the replies and the sticky is that it IS ok to simply recirc the water.
    IMHO, it would be better than nothing, but I could be wrong!
    Grace
    AVID reader of this forum
    but alas, no pool, yet!
