Thread: calcium hardness
    Default calcium hardness
    Is calcium hardness important in a vinyl inground pool? The pool is about 8000 gal and my latest numbers are FC-7 / PH-7.4 / TA-110 / CC-0 / CYA-60-70 / CA-140 down from 250 from last weeks test. Water is crystal clear, also I am using an Aquarite SWCG. Should this be adjusted?
    waterbear's Avatar
    St. Augustine, Fl
    Default Re: calcium hardness
    If you don't have a heater then your lower calcium level will be a benefit since it will cause much less scaling in you SWG! Even with a heater your calcium levels should be fine!
  1. Calcium Hardness
    By kinetique in forum Dealing with Alkalinity and Calcium
    Last Post: 11-15-2012, 07:12 PM
  2. calcium hardness
    By walker1 in forum Dealing with Alkalinity and Calcium
    Last Post: 09-08-2012, 11:49 PM
  3. What should Calcium Hardness be?
    By troykristoffer in forum Dealing with Alkalinity and Calcium
    Last Post: 05-31-2007, 12:49 AM
  4. Calcium Hardness
    By Ciscokid in forum Dealing with Alkalinity and Calcium
    Last Post: 05-30-2007, 03:29 AM
  5. Calcium Hardness
    By PaulE10 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 04-15-2006, 11:52 AM
