Thread: Aquachem pH reagent
    Default Aquachem pH reagent
    Hi;
    I need another bottle of Aquachem's pH reagent phenol red (phenolsulfonephthalein), offhand Taylor offers both R-0004 and R-0014 and I think a couple others. Anyone know which (R-00XX), one it is?
    Thanks,
    Jo
    24,000 Gal IG Pool ColorQuartz Premium
    1,000 Gal Spa - 8 Jets
    System 3 D.E. Filter,
    Max-E-Therm Heater
    550 Sq Ft Heliocol Solar System
    Intellitouch i7 & Goldline Aquarite SWCG
    SAm & SAl lighting, 2-2HP pumps
    Filled 6/21/2006 Owner/Builder
    Default Re: Aquachem pH reagent
    The R-0014 would be the closest. The R-0004 won't work. It is designed to be used with a 45 ml water sample.
    pool newby is offline ** No working email address ** Thread Analyst pool newby 0
    My aquachem professional test kit has a 800# you can call, and supposedly they will send you more reagent free. I haven't tried it yet, but probably will soon as I will be needing some more CYA reagant. I'm hoping they will be responsive, they did send me some free test strips when I registered online. If you need the number, let me know, and I'll get it for you.
    Bob P
    pool newby
    18' Pacifica ABG, 8600 gallon,Waterway 26 inch sand high rate sand filter. 2.5 hp dual speed pump
    Thanks Bob my AquaChem has the numbers too. But I'd like to switch to the more readily available Taylor reagents. I was hoping to do it without having to acquire another hunk of plastic box and sample/comparator cells. If I can't switch directly I'll give up and buy a taylor oto kit and just add more dinosaur to the landfill.
    Jo
    Max-E-Therm Heater
    I have an Aquachem and two Taylor kits (among others). the Taylor is much easier to read and the color match much better on the comparator. IF you just want pH get a taylor K-1000 OTO and pH kit (Or Ben's PS200...basically the same kit for less money). It's very inexpensive. Otherwise get a K-2006 or better yet, get Ben's PS234...much better value for the money (and you can use the taylor reagents with it if you need to)
    Hi Evan;
    I already own an AquaChem professional and the Taylor 2006C. I just wanted to do the pH without a 44 ml sample.
    As for the accuracy I can't really complain my AquaChem has been right on the dot with the Taylor. Since I use the AC daily and once a week test with both for a QA check of sorts.
    Thanks for the input I really appreciate it,
    Jo
    Max-E-Therm Heater
