Results 1 to 10 of 19
Thread: Chlorine Enhancer ???
    Jul 2006
    Tucson, AZ
    Question Chlorine Enhancer ???
    Hello,
    We recently bought a home with a 12,000 gallon pool. So far I have not had any problems and I thought I was doing a fairly good job maintaining it. Recently the water was looking cloudy and I noticed what looked like some algae around the edges. It was only a little bit. I took a sample of water the the pool store and they said all my levels were within normal range. They did sell me a chlorine enhancer which is supposed to aid in the control of algae. Well I used it that day and shocked. This was about a week and a half ago and ever since then the chlorine level on strips and drops has been zero. I have shocked several times but it doesn't seem to lock the chlorine in. The water is still cloudy, it comes and goes. Some days it is not as cloudy as others. I also live in Tucson, AZ and right now it is Monsoon season. Lots of rain and wind. Could the weather be contributing? I thought you might be able to help with the chlorine enhancer situation because on the websites Tips actually tip # 44 is says if you've used one of these products and your chlorine has gone AWOL to e mail. So here I am. Please help. Thanks.
    Mandy
    Default Re: Chlorine Enhancer ???
    Hi Mandy,
    Chances are good that the chlorine enhancer they sold you was bromine, MPS, or a non-chlorine shock, so now the chlorine you're putting in the pool is fighting the enhancer, not the problem. The only chorine enhancer you need is more chlorine.
    If you will please post test results taken with a DROP-BASED kit for Cl, CYA, pH, TA, I'm sure we can help you get your pool clear. Chances are very good that you just have a very high stabilizer level and haven't gotten your Cl up high enough to take care of the algae, but we need to see the numbers to give you any real help. Also, I'm moving this post to the Chlorine forum so you'll get more responses and views.
    Welcome to the forum!
    What is the name of the product you used? It probably contains either inorganic ammonia or sodium bromide. The inorganic ammonia will form monochoramine in the pool, which is effective at killing alage but very short lived. You will have a high chlorine demand until the ammonia is burned off. Keep shocking until your chlorine levels are holding.
    If it was sodium bromide it has temporarily converted your chlorine pool to a bromine pool. Bromamines are effective at killing algae also but you will have a huge chlorine demand until all the bromine is gone...once again, keep shocking until your chlorine is holding.
    In either case you might need a lot of chlorine and you might need to be adding it a minimum of morning and night (3 times a day is better) to get rid of the ammonia or bromine.
    Neither one of these types of products are really necessary for killing algae. All you need is chlorine and POP (Pool Owner Patience).
    IMHO, sodium bromide has a place in very special circumstances but should not be used as a first line of attack against algae. Can't comment on the inorganic ammonia ones since I have no experience with them. If you want to use an algecide in conjucntion with chlorine then use Polyquat 60 (a type of algecide, not a brand) and nothing else!
    Jul 2006
    Tucson, AZ
    Smile Re: Chlorine Enhancer ???
    WOW thank you so much for replying to quickly. I just checked my levels and they were Cl .5 pH 7.5 TA 160 and I am out of drops to test for CYA. A week and a half ago at the pool store they said the CYA was normal.
    The product I used is called Green to Clean and it lists the active ingredient as disodiumsalt of ethylendiaminetraaceticiddihydrate,diammonium sulfate
    So you think the pool may still be cloudy because of the algae growth. I really can't see any algae at all anymore. But the water is very cloudy I can't even see the main drain on the bottom at 8 ft down. Do you think monsoon season may have anything to do with it?
    I doubt the monsoon season has anything to do with it, unless it's dumping lots of stuff in your pool, or it's adding a lot more water and effectively diluting your chlorine--you need to be extra careful about keeping your Cl up during those rainy seasons.
    There is no "normal" CYA level at a pool store--if you ask them the appropriate range, they'll tell you it's 20-200. That's a HUGE difference in Cl levels required. However, I can tell you that Cl of .5 isn't high enough, even with a low CYA level. I'm assuming your pool is vinyl liner--I would go ahead and shock the pool, using bleach, to 10 ppm while you're getting an accurate CYA reading. From there, we can adjust your Cl as necessary to get your pool cleared up. I wold also keep the filter running until it clears, and DONT put any more of the algaecide in it!
    You have used an ammonia based algecide. The pool is probably cloudy beause either you have not killed all the algae or there is dead algae in the water. In either case you need to get the pool to shock level and keep it there until your chlorine is holding overnight. How high you need to bring the chlorine level up depends on your CYA level. See this chart
    http://www.poolforum.com/pf2/showthread.php?t=365
    There is no such thing as a 'normal' cya level. The recommended level for a manually chlorinated pool is 30-50 ppm. Some pool stores seem to think that levels as high as 200 ppm are ok! (they are NOT). You really need to either post your last test results for CYA or get a new set of tests and post them and we will be able to help you clear your pool!
    Jul 2006
    Tucson, AZ
    Okay I will shock the pool. What kind of bleach? Household bleach. I always buy those 1 lb bags of shock. Also, the pool is plaster. Is is silly to take my water in to the pool store? I need to get a reading for CYA. It seems like they try and sell you stuff you don't need. Also, is it better to shock at night?
    Mandy
    Jul 2006
    Tucson, AZ
    Question Re: Chlorine Enhancer ???
    When adding bleach to the pool should you add it in the deepest end, around the edges, the whole pool surface ????? I've never used bleach and I am not sure how to go about it? How soon afterwards should I check my FC level? I can't believe I've been spending so much on bags of shock when I can use bleach! Should I still use chlorine tablets in the floater???
    Mandy
