Results 1 to 10 of 19
Thread: Chlorine Enhancer ???
    Default Re: Chlorine Enhancer ???
    Yes, we're talking about household bleach, but it needs to be plain, unscented....no added perfumes or "extra whitening ingredients" or anything fancy like that. In a pool your size, 3 cups of 6% bleach will raise your chlorine by 1 ppm. How high you need to go depends on your CYA level, which you need to test for. A pool store can test for it, but make sure they're not using strips--make sure they're using the liquid reagents. It isn't silly to go to the pool store for testing, as long as you don't buy any of the chemicals they try to sell you, right off the bat. For example, pool stores worldwide will convince people that their calcium is WAY too low and they must add some RIGHT NOW!!! but calcium is irrelevant in a vinyl pool. Or they'll try to insist you need to buy 4-5 pounds of alkalinity up, which is the exact same thing as Arm & Hammer baking soda at 5 x the price. So....I strongly encourage you to invest in a good, drop-based test kit and forget the pool store. Taylor carries a good one, but most of us use the one sold by the owner of this site. Cost is $70, but it will test for most anything you need, and pay for itself over and over again in the first year. It'll also keep you from getting "pool-stored"!!
    Since you referred to the tabs, I'm guessing you've been chlorinating with trichlor, which confirms my suspicion that your CYA is way too high--but have it tested anyway and post back. And when you add bleach to the pool, you can either walk around the perimeter and stir as you pour, or pour it directly into the return stream, it doesn't matter--just make sure it doesn't collect as a "hot spot" around th edges of your liner. It is better to shock at night, so the sun gets as little of your chlorine as possible, and I would stop using the pucks for now until we have a good CYA number.
    Jul 2006
    Tucson, AZ
    Smile Re: Chlorine Enhancer ???
    Janet-
    Thanks for the info and for being so kind. I am on my way to the store to buy more CYA reagent.I have strips and the drop test kits. What a waste of money on the strips! The drops that I have test for total chlorine, bromine, pH, TA, Total hardness and CYA. I am already out of the CYA, but like I said I will buy more. Is there any other tests I should perform? Also going to pick up a couple of jugs of bleach. I will post my CYA results as soon as I get them. Hopefully you will be able to help me determine how much bleach I need.
    Thanks again,
    Mandy
    Those are all the tests that you need for now. Ignore the scale for bromine, just read the chlorine side. You also probably need to pick up more like 3 or 4 jugs of bleach. Post your numbers, and we'll be glad to help.
    Jul 2006
    Tucson, AZ
    Question Re: Chlorine Enhancer ???
    Well I was able to pick up bleach but the pool store is closed already I guess because it's Sunday. I tried WalMart, Loes and KMart and no one sells just the CYA reagent. I hate to spend the money for the whole kit when all I need is the CYA. I guess I will wait until tomorrow to test for it. For the time being should I put in some bleach just to be safe??? If so how much?
    Mandy
    Without knowing your CYA level, it's anybody's guess. I'd just wait until tomorrow, get your test kit, test your water, and go from there. Just pouring bleach in at random is wasting bleach.
    Jul 2006
    Tucson, AZ
    Okay... I finally have my CYA results.
    FAC 0
    TAC 0
    pH 7.6
    TA 130
    CYA 0
    I know I need to add conditioner, but how much. My pool is a 12,000 gallon plaster IG. The water is clear,but green. It's super hot here in Tucson about 105 degrees today. The pool is at 91 degrees. Once I get this all done how much chlorine should I add, how often and do I still need to put tabs in a floater since I am converting to BBB????
    Thanks!!!!!!
    Mandy
    Follow the directions on the label to get your pool to about 20 ppm CYA to start with. Put it in the skimmer, and don't retest for it or backwash for a week, because it takes a long time to dissolve. Add enough bleach to get your Cl to 15 ppm. In a pool your size starting at zero Cl, it should take about 3 gallons to get to 15. YOu'll need to test 2-3 times daily, if possible, and add whatever amount each time it takes to get back up to 15. The more often you test and add, the quicker your pool will clear. Keep your filter running 24/7, and brush daily while you're clearing your pool.
