Results 1 to 10 of 12
Thread: pH Testing
    Middle Missouri
    Default pH Testing
    I think the pH in my water is testing about 7.4 or maybe 7.6. I have a devil of a time deciding where I am on the pH scale. Seems like there are two issues for me: color match and (for lack of a better term) translucence. In my latest sample, the color is kind of pinkish, more closely matching the colors in the 7.5 to 8.2 range. But the translucence most closely matches the lower range (yellowish) values of 7.2.
    Yes, I am judging the samples in full daylight, holding the sample about 6" away from the white panel in the lid of the test kit case.
    Is this a problem for anybody else?
    -Jim
    Jim
    16' x 32' / 15,400 gal / IG vinyl
    All testing done with
    PS234 test kit
    Default Re: pH Testing
    Here is an easy way to tell the pH when using phenol red indicator (which is what is found in every test kit I have ever seen!)
    If the color is red (actually more pinkish) or purple your pH is too high! 7.8 or higher
    If the color is yellow to yellow orange your pH is too low 7.0 or lower
    If the color is orange to orange red your pH is perfect 7.2-7.6
    You are looking for the color of the indicator..not how deep or light the color is!
    A good way to learn the colors is to put some water in a small vial with a cap,add some phenol red so you can see the color well but not so much that it's very deep. add a TINY pinch of borax, cap and shake to make the color purple, then add vinigar drop by drop and cap and shake after each drop and watch the colors change from purple to red to orange to yellow. Phenol red will test pH from 8.2 down to 6.8....purple means 8.2 or HIGHER, yellow means 6.8 or LOWER. An orange color is about 7.4-7.5 which is pretyy much perfect!
    Caledon, Ontario, Canada.
    get your wife or GF to look at the colors.
    The have a better eye for the differences.
    Middle Missouri
    I haven't had a chance to try Waterbear's suggestion yet, but this is a good thought, Brent. Maybe I'll get both of them to look at it.
    -Jim
    (...aw, they're one in the same.)
    Brent, I'd like to meet you over on CarlD's Dolphin thread 'cause I've got a question. See you there?
    Jim
    PS234 test kit
    Middle Missouri
    Evan, I tried your suggestion of using borax and (white) vinegar to bring a water sample through a range of colors representing high to low pH. The colors showed beautifully beginning with something in excess of 8.2 and changing to the orange that represents the the more acid. I got to a point where the color matched the 7.5 sample perfectly. Then I added one drop of vinegar (with a medicine dropper) and the resulting color matched 7.2 perfectly.
    I did not experience the ambiguity (or translucence) of color that I experience when I test my pool water. So I've got to say that the experiment for me was somewhat inconclusive.
    I do appreciate your suggestion and the attempt to help.
    -Jim
    Jim
    PS234 test kit
    The color is the only important thing. match the colors. I really don't underatand what you mean by translucense. Do you mean the intensity of the color?
    Lafayette, La
    Quote Originally Posted by waterbear
    Waterbear- this should be a sticky so that all newbies can truly understand what they are looking at. THIS IS A GREAT DESCRIPTION- thank you
    Middle Missouri
    Quote Originally Posted by cheshamjim
    I've been doing that. I probably have some color perception deficiencies.
    Thanks,
    -Jim
    Jim
    PS234 test kit
