Results 1 to 10 of 12
Thread: pH Testing
    Caledon, Ontario, Canada.
    Default Re: pH Testing
    get your wife or GF to look at the colors.
    The have a better eye for the differences.
    Middle Missouri
    I haven't had a chance to try Waterbear's suggestion yet, but this is a good thought, Brent. Maybe I'll get both of them to look at it.
    -Jim
    (...aw, they're one in the same.)
    Brent, I'd like to meet you over on CarlD's Dolphin thread 'cause I've got a question. See you there?
    Jim
    16' x 32' / 15,400 gal / IG vinyl
    All testing done with
    PS234 test kit
    Middle Missouri
    Evan, I tried your suggestion of using borax and (white) vinegar to bring a water sample through a range of colors representing high to low pH. The colors showed beautifully beginning with something in excess of 8.2 and changing to the orange that represents the the more acid. I got to a point where the color matched the 7.5 sample perfectly. Then I added one drop of vinegar (with a medicine dropper) and the resulting color matched 7.2 perfectly.
    I did not experience the ambiguity (or translucence) of color that I experience when I test my pool water. So I've got to say that the experiment for me was somewhat inconclusive.
    I do appreciate your suggestion and the attempt to help.
    -Jim
    Jim
    PS234 test kit
    The color is the only important thing. match the colors. I really don't underatand what you mean by translucense. Do you mean the intensity of the color?
    Middle Missouri
    Evan, I tested my pH this a.m., keeping your suggestions in mind - the color is the thing!
    Looks like my pH is at about 7.8, definitely purple, just not quite as intense a purple as the color at 7.8 on the comparator. However, the sample doesn't have that yellowish tinge that the 7.5 scale has.
    Since I can't explain what I mean by "translucence" I'll give up on that term and just remember to pay attention only to the color no matter how translucent it is.
    Thanks again for your help.
    -Jim
    edit: maybe intensity is the word.
    Jim
    PS234 test kit
    Quote Originally Posted by cheshamjim
    -Jim
    What test kit are you using. Sounds like the problem is your comparator. Some of the cheaper ones just don't match the colors of the indicator very well. the Aquachem test kit is a good example of this! That is one of the reasons why it is worth the money to get a good test kit like Ben's ( or one from Taylor or LaMotte).
    Intensity of color is where the cheaper comparators usually fail. If you are seeing a purple color your pH is definately about 7.7 or higher. 7.5 will have a definite orange color with just a hint of red in it. 7.6 is a faily pure pinkish red color.
    Middle Missouri
    I'm using the OTO/Phenol red testkit that came with Ben's testkit. Maybe I should try to find a better color comparator somewhere?
    -Jim
    Jim
    PS234 test kit
