Results 1 to 10 of 15
Thread: Why is Ph climbing?
    Default Re: Why is Ph climbing?
    Quote Originally Posted by Rangeball
    N=1, but in my and my pool's experience when I was aerating ALK rose along with PH until I got the ALK below 200. Even then, ALK only drops after I add the acid and let PH drop THEN aerate, and ALK remains constant.
    Did you phrase that correctly? When you are aerating, your alkalinity rose along with pH? Or did you see it drop?
    Before you got started with the aeration, you may have had a tendency to drift in pH due some acidic or basic process in your pool. It's hard to isolate the different pieces since it is an open system.
    Richard
    IL.
    If I recall correctly, when my alk was very high as PH rose, alk tended to rise as well. It may very well have been from the process you stated occuring simultaneously, but when my ALK is below 200 it isn't as noticeable.
    In any event, simply aerating has never lowered my alk. I had to reduce it with acid first, and try to hold it there as I aerated to bring PH back up.
    My point exactly. Simply aerating just increases the pH (ignoring the increase in alkalinity you saw at high alkalinity levels). It is the adding of acid that lowers the alkalinity (and also lowers the pH). The reason you add the acid first is that the outgassing of CO2 is more rapid at lower pH so by adding acid first you make the process more efficient (occur more rapidly). It would still work if you aerated first and then added acid -- it would just take a lot longer.
