Results 1 to 9 of 9
Thread: Req for comment on high calcium numbers
    mas985's Avatar
    Pleasanton, CA
    Default Re: Req for comment on high calcium numbers
    Did I read correctly? An above ground (AG) plaster/gunite pool/spa? I would like to see a picture of that.
    High calcium can cause scaling and rough plaster. However, your PH and alk are good so you may not have experienced it yet. If it were my pool, I would try to get it below 400. Replacing 1/2 the water should work.
    Mark
    Grand Prairie, TX, USA.
    Quote Originally Posted by mas985
    Whoops...should read 'IG'.
    About a month ago, I started the conversion from Leslie's Pool Supply's 3" Jumbo Tabs (trichlor...) and Power Powder Pro shock (73% calcium hypochlorite) to laundry bleach, based on the readings from this forum as well as other sites. The pool has been in service since Labor Day weekend 2003. Is it likely that my calcium has always been high due to the new plaster, or does my weekly shock using the cal-hypo tend to increase the hardness?
    --Rx
    15,000 gal IG plaster/gunite pool & spa w/gas heater, 60 ft2 DE filter
    Your shocking with cal-hypo definitely contributed to the hardness.
    Dec 2005
    Orange, CA, USA.
    My pool is running 600 as well. It's a new IG plaster, and from what I read, the calcium added to the plaster contributed to the rise. Our tap water is at 200. It's been running this high for the last 6 months. I've checked the salt cell and no visible build up. However, the spa spillover (12") literally has pea sized calcium deposits on the tile at the bottom. Just this weekend I made a 5-1 mixture of water/Muriatic Acid and it worked like a charm. Just sprayed.. Sizzled, spray, sizzle.. took about 15 minutes.. No scrubbing. I do plan to drain and refill at the end of summer though. Haven't noticed any buildup/roughness on the plaster yet and I do actively check each time I'm in the pool. I keep my Ph around 7.5 and Alk 90-100.. No cloudy water...
    karrde97 is offline Registered+ Thread Analyst karrde97 0
    Peoria, IL
    I talked with someone last about his IG which high Calcium awhile ago. He bought an old water softener and hooked it up to his system. After a few days, his Calcium was lower. Anyone else done this?
    SoCalBoo is offline Registered+ Thread Analyst SoCalBoo 0
    San Diego
    karred97 - i thought about something similar. the problem I kept coming up with my hypotheticla plan was that every water softener I've seen discharges in the neighborhood of 2 gallons of brine waste for every one gallon returned (softened...i.e, calcium reduced). So you are gonna have to pour off most of he pool water anyways, just to get softened water back into the pool. Why not just drain off and refill. Seems a whole lot easier. Then again, maybe I am missing something.
    After 50% water drain & refill: FC: 7, CC: 0, pH: 7.2, Alk: 70, Cal: 340, CYA: ~20.
    I held the FC at 13.5 for approx. 24 hrs. Now I'm letting it drop down to the best guess range. Also, I've stopped using the remains of my cal-hypo shock powder so I don't drive my calcium up again.
    Thanks for the tips/replies.
    --Rx
