Re: Req for comment on high calcium numbers
I'd keep your Alkalinity down toward the lower end of the ideal range and enjoy your pool. If, as the calcium gets higher, you get to the point where you can't keep the water clear, then you might need to do a partial change to get the calcium down. Since you have a heater, you should probably calculate the saturation index and use that to help guide you to the best pH to minimize issues with scaling in the heater.
