Results 1 to 10 of 12
Thread: Must be doing something major wrong
    Sun Prairie, WI
    Default Re: Must be doing something major wrong
    Hang in there Karen! You will beat this! I have seen it many times on here, how it looked so hopeless but with the support of the forum, the algae lost.
    Some pool stores will carry the Chlorine FAS-DPD Kit. Not many in my neck of the woods do, some can order it. I think you best bet to get one fast is to do what Carl suggested and order one on-line and have it shipped overnight. I can send you some links to on-line retailers that I have dealt with if you like.
    I add the bleach to the skimmer. From what I have read here that is how a lot of people add it. You should be fine adding it by the return or spread it around the deep end. Do not add to the skimmer if you have or have had pucks in your skimmer.
    With a CYA of 100 you need to shock to and hold a level of 25 PPM according to Ben's best guess chart. You will need to add bleach several times a day to keep the levels up.
    Running the filter 24/7 is a good thing. Keep brushing, brushing and brushing.
    With a CYA of 100, to get to 25 PPM from 0 PPM in a 32,000 gal pool you will need 13.3 Gal of ultra bleach (6%).
    If you are at a CYA of 90, get to 20 PPM from 0 PPM with 10.7 gal of ultra bleach (6%).
    Yes you are getting it.
    GOOD LUCK! AND KEEP WITH IT!
    ~Dr. Spike
    Pool: IG vinyl, heated, fully enclosed (dome)
    Shape: Grecian (rectangular)
    Size: 20'W x 40'L
    Depth: 4' / 8'
    Filter: Sand w/DE added
    Other: 6' Diving Board
    Maintenance: BBB! Ben's PS234 kit! Manual vacuum, brush, and Pool Buster Max CG Gold
    Jul 2006
    Thanks for the words of encouragement. Needed that.
    Please do send the links as to where I can order the test I need. Which one is best or are they both about the same?
    Thanks again
    Karen
    Sun Prairie, WI
    Karen,
    You are welcome!
    Check your PM.
    ~Dr. Spike
    Size: 20'W x 40'L
    Depth: 4' / 8'
    Jul 2006
    Will check them out tomorrow
    Karen
    Karen:
    The Leslie's kit and the Taylor kits I mentioned are chemically the same--Taylor MAKES Leslies' kits for them.
    Ben's kit, the PS-234 is basically the same, and I believe it's chemically the same (the PS-233 certainly is). Ben gives you better instructions, more refills, a log to record stuff, and leaves out the useless acid demand and base demand tests. But you need this RIGHT NOW and he can't get it to you that fast. So plan B) is the Taylor or Leslie's kit.
  1. A MAJOR problem
    By SL Dan in forum Dealing with Algae & Slime
    Last Post: 09-01-2011, 05:53 PM
  2. Major Renovation & First Post
    By scavdog in forum In-Ground Pool Construction and Repair
    Last Post: 06-22-2010, 09:58 PM
  3. Major Pool Renovation Stairs
    By OldPoolNewOwner in forum In-Ground Pool Construction and Repair
    Last Post: 10-30-2007, 09:38 PM
  4. Major problems, advice needed...
    By Strawfoot in forum In-Ground Pool Construction and Repair
    Last Post: 12-14-2006, 02:22 PM
  5. Newbie with MAJOR problem...
    By MyBlueDog in forum In-Ground Pool Construction and Repair
    Last Post: 06-18-2006, 07:23 PM
