Thread: High bromine
    Jul 2006
    Default High bromine
    I have a 12x3 quick-set pool. I'm using vinyl pool shock. The test trip indicates high bromine (all other levels are fine). What does this mean, and how do I fix it?
    Default Re: High bromine
    Ignore it, unless you're using bromine for sanitation, which I doubt you are. Most of the chlorine OT tests also have a bromine scale that confuses new users, but unless you're putting bromine in your pool (it's often used for spas), ignore it.
  1. Bromine pool - no detectable bromine.
    By ptrdvs44 in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-17-2012, 05:58 PM
  2. Bromine and Chlorine
    By jtagscott in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-09-2012, 10:18 PM
  3. CYA in a Bromine Pool
    By chem geek in forum The China Shop
    Last Post: 07-21-2010, 08:28 PM
  4. Anyone else have a bromine pool
    By swreeder in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-24-2007, 12:45 AM
  5. testing for bromine
    By dsmith6666 in forum DPD-FAS based testing
    Last Post: 10-06-2006, 12:04 PM
