Re: Do you ever have to replace sand in a sand filter
Thanks to all, I did end up changing it, the good advice of the pool center was "when in doubt change the sand" He noted that sand is cheap and you can spend lots of $$ on chemicals trying to fix the issue (and still end up back at the sand). Didn't even try to sell me chemicals!! He told me to stop when I could see the laterals so they would have support and not break off, and to fill the tank about 1/2 way with water to lessen the shock of the snd on the laterals when dumping it in. Time consuming, but easy. I seem to be able to clean up now so I guess that really was it!
