Thread: Adding calcium...when & where
    AndieP is offline Registered+ Thread Analyst AndieP 0
    Jul 2006
    Oklahoma
    Default Adding calcium...when & where
    I need to add calcium to our pool and I think I need to do it soon. (concrete/plaster pool Calcium level at 100)
    I have been keeping my chlorine level high during the conversion process so my questions are:
    Is it OK to add calcium with a high chlorine level?
    Is there a better time to add it day vs night?
    The bottle says broadcast around pool....is that the best way to add or should I add at the skimmer?
    Should I add it all at once (I will probably need about 20 pounds) or add in intervals?
    Should I wait for a certain number of days to backwash once it is added?
    Thanks!
    Downingtown, PA
    Default Re: Adding calcium...when & where
    You can add calcium while the chlorine level is elevated, just wait an hour between dosing different chems. With the pump running, I will broadcast it across the deep-end and then help stir up the water with the leaf net or by jumping in. The calcium should dissolve within a couple hours so backwashing should not be a problem (besides losing some calcium in the water you dump). Also, I do not think it matters when you add your calcium but I would probably add 3/4 of the total you need and then wait a few hours, test and add the rest as needed.
    Outside of Philadelphia, PA
    18' x 40' IG - 22K gallons
    Sylvan Gunite Pool (1979)
    Plaster re-done (1997)
    IL.
    What are you using for chlorine?
    Seems like this would be a perfect situation for calcium hypochlorite.
    Downingtown, PA
    Ditto... I had cut it out of my post but good question & point.
    Jul 2006
    Oklahoma
    I have been just using bleach to this point.
    Prior to switching I was using calcium hypochlorite as a weekly shock (I was using Pristine Blue) My pool supplier had me discontinue it because "maybe the calcium was clouding the water....didn't need the calcium anyway."
    Should I go back to the calcium hypochlorite as a shock and bleach as daily sanitizing? How much calcium does it add?
    I was cleaning the pump basket and noticed pieces of white paint or plaster in it
    I am beginning to think we would be better off just closing the pool down
