Test Kit PS234 Results
New 27' 17,000 gal AG Vinyl Liner. South Louisiana.
Added chemicals pool store recommended (know better now), then ran tests. Water had metal in it and ran Metal Magic for 48 hours before adding other chemicals, which including Water Hardness Increaser (knowledge gained from Forum too late). Water is quite cloudy at this point. Here are my numbers:
FC=1
CC=0.5
TC (tested)=0.5
pH=7.2
ALK=130
Cal=230
Cya=0 (even though 5.5 lbs of stabilizer is hanging in pantyhose in pool at 2 locations, per pool store).
From the info on Forums, I gather I should start adding bleach to raise my FC to Shock Level of 10 ppm until my water gets clear.
If that is correct, is there anything else I should be doing to get my wife and kids in the pool before they mutiny and make me walk the plank?
Thanks to all-great Forum.
