Thread: DE Filters - How often do they need to be cleaned?
    Default DE Filters - How often do they need to be cleaned?
    I need some info on the DE filter. I know for the sand filters, you
    need to replace the sand inside the filter every so often. How does it work
    with a DE filter?
    MaryLee is offline Registered+ Thread Analyst MaryLee 0
    Southern New Hampshire
    Default Re: DE Filters - How often do they need to be cleaned?
    As soon as the pressure rises 10 psi from its original starting pressure, then it's time to backwash.
    Edited to add: The difference is that with a DE filter after you backwash, you need to recoat the grids with DE....this involves putting the recommended amount of DE for your size filter into the skimmer and letting it recoat. I believe with sand filters you can leave the sand in it for years and years before it needs to be replaced (if at all).
    18 X 40 IG Vinyl
    3 1/2' ft to 8' deep
    Pentair DE Filter
    400K BTU Pentair Minimax heater
