Thread: Does my filter backwash?
    Default Does my filter backwash?
    I see all this talk of backwashing and I don't think I can do that with my system. I have a Star DE-50 filter and I see nothing about "backwashing" in the instructions anywhere. It talks about swishing and bumping but I don't see anything about backwashing. Anyone have this filter and/or know anything about it? Thanks!
    Default Re: Does my filter backwash?
    just bumping to see if anyone knows anything about this. Thanks!
    IL.
    Quote Originally Posted by denanbob
    That'd cinch it for me.
    I'm guessing you bump and swish to redistribute the de, but once the pressure rises and stays up even after bumping and swishing, I bet you have to break it down and clean it.
    Not all DE filters can be backwashed. You can bump them which means you knock the DE off the laterals so it can mix with the dirt that was filtered out and then recoat the laterals with dirty DE. (I am not a fan of bumping a DE filter). To clean them you have to break them down which, IMHO, should be done whether a DE filter is backwashable or not! (I am also not a fan of backwashing a DE filter. I have posted the reasons several times in other posts.
    just my 2 cents.
  1. DE filter backwash (newbie)
    By hikernut in forum Pool Equipment & Operations
    Last Post: 06-11-2013, 03:53 PM
  2. PSI to Backwash a DE Filter?
    By Shifty in forum Pool Equipment & Operations
    Last Post: 07-07-2012, 03:08 PM
  3. How often do you backwash a sand filter?
    By tokmom in forum Pool Equipment & Operations
    Last Post: 06-30-2012, 09:52 AM
  4. Backwash Filter
    By Tntoygirl in forum Above-Ground Pool Construction & Repair
    Last Post: 07-08-2011, 08:37 PM
  5. DE in Sand Filter...how often to backwash?
    By jstkiddn in forum Pool Equipment & Operations
    Last Post: 06-22-2011, 11:00 AM
