Re: PINK bacteria in the filter (Cartridge)
I am sure I let my chlorine levels fall too much and too often. I use bleach and have a puck tower in use. Here are my numbers from my local pool store. Pinpoint computerized water analysis... FC 1.3 TC 1.9 CC .7 pH 7.6 CA 38 TA 140 CH 285 Temp 75. Very hard makeup water(well).
FYI... Pool store notes that local commercial pool operators have been having luck dosing chlorine pools with bromine to control/kill pink "algae".
Pool tends to move to 7.4... keep adding Borax to maintain 7.6+ Any suggestions on getting the TA down... muriatic acid? What will happen to my pH then?
Fiberglass IG with hot tub/18,500 gallons
