Closed Thread
Results 1 to 4 of 4
Thread: 20 / 28 mil liner?
    Default 20 / 28 mil liner?
    Which should I go with? Either 20 or 28 mil vinyl liner.
    Pool size 17 x 33
    Yes I am a newbie
    Grecian 17'x33' Vinyl liner pool
    ZeoBrite filteration
    SWG Aqua-rite
    Sta-Rite Dura-Glas 1.5hp pump.
    SAM Light
    21037.5 gallons
    Tennessee
    Default Re: 20 / 28 mil liner?
    Barring price I would go with the 28 mil liner. They will hold up better and useally have a better warranty.
    So as for stretching issues. 28ml will just hold better, But if it is not able to give any (stretch as good as 20ml) while being stretched like the 20ml, would the 28ml will more likely rip b/c it does not giveas much?
    Yes I am a newbie
    SWG Aqua-rite
    SAM Light
    21037.5 gallons
    Tennessee
    I didn’t install mine but I feel that a correctly fitted liner shouldn’t have to stretch to the ripping point. I understand that heat from the sun will help the liner stretch and form better.
Closed Thread
  1. J-channel holding liner in corner broke off, liner is sagging
    By TRHOD12 in forum In-Ground Pool Construction and Repair
    Last Post: 05-09-2011, 04:41 PM
  2. Wrinkled Liner and Water Behind Liner
    By rbposey in forum In-Ground Pool Construction and Repair
    Last Post: 09-26-2009, 05:40 PM
  3. Do I need "Liner Lock" for Beader Liner
    By Aranon in forum Above-Ground Pool Construction & Repair
    Last Post: 04-30-2006, 12:04 AM
