Results 1 to 10 of 12
Thread: DPD powder
    Jakebear is offline Registered+ Thread Analyst Jakebear 0
    Jul 2006
    Pennsylvania
    Default Re: DPD powder
    Quote Originally Posted by CarlD
    You only need enough DPD powder to turn the water nicely pink. Any more just wastes the powder--it doesn't turn it pinker. It seems weird, but that's how the stuff works.
    I was having problems with getting any CC results using my FAS-DPD kit. When I called Taylor Technologies technical service, they told me that the amount of powder used is important.
    Being a skeptic (and Cheap) I ran some tests. I ran the same sample 8 times --- 10ml 1 scoop, 10ml 2 scoops, 25 ml 1 scoop and 25ml 2 scoops. The results consistently gave more accurate results (less variation) when two scoops of the powder were used. The difference was 1.8 ppm higher when using the preferred (by Taylor) method using the 25ml sample size. I did the same routine over again --- the results were repeatable!!
    Thought you would want to know!!
    27038 Gallon InGround, Vinyl, DE filter.
    So when you say 2 scoops, what scoops are you referring too, Ben's scoop (White) or Taylor's (Blue)?
    Dave
    atwetzel is offline ** No working email address ** atwetzel 0
    Jul 2006
    And are those level scoops, rounded scoops, heaping scoops?
    Jul 2006
    Pennsylvania
    Taylor scoops (blue) --- Level
    Edit --- Didn't know there was more than one since Taylor makes the reagent.
    Mesa, AZ
    I've seen both scoops, The poolsolutions scoop is much bigger than the taylor. I've tried the 10 ml test with 1/2 and whole scoops of Ben's scoop, and the test was the same for normal levels of chlorine. If I'm measuring shock level chlorine, I make sure I get a whole scoop just to be safe
    Quote Originally Posted by Jakebear
    That explains it, you are supposed to use 2 scoops when using the Taylor scoop. Ben, the forum moderator, puts a larger scoop in his kits (he does use Taylor DPD powder). They are twice the size of the Taylor scoop so you only need one scoop. I think he did this to make it just that much easier. Ben has really put a lot of thought into his kits. The size of the re-agents is another example. He matches volumes of re agents to the amounts required for testing with the idea that you should use both chemicals required for any given test up at or about the same time. His kit is a combination of a a coupe of the Taylor kits at a great price.
    Dave
  1. DE powder
    By jcolwell in forum Pool Equipment & Operations
    Last Post: 05-18-2012, 05:31 PM
  2. What is DE filter powder for? What does DE powder it do?
    By ybortony in forum Pool Equipment & Operations
    Last Post: 04-11-2012, 12:08 PM
  3. FAS-DPD powder
    By Macrosill in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-08-2007, 03:15 PM
  4. DPD Powder
    By jrv331 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-06-2006, 11:37 PM
  5. DPD powder
    By Poolidiot in forum DPD-FAS based testing
    Last Post: 05-20-2006, 11:05 PM
