Results 1 to 10 of 13
Thread: an idea i'm going to try for spring startup and chlorine generators
    duraleigh Guest
    Default Re: an idea i'm going to try for spring startup and chlorine generators
    tenax: (to the kids in the pool playing near the return) "Fore!!"
    kids in the pool: "ouch!"
    (Okay, no more scotch for me!)
    ouch ok..so i'm clear, i have 1.5 inch piping..but the manifold itself will be 2 inches with the autopilot soft touch, i'm assuming? if correct, you're saying don't use a golf ball period unless everything is 1.5 inch (i thought the autopilots all had 2 inch piping?)
    thanks
    Ft Lauderdale, Fl
    YES....and NO. We do have a 2" manifold assembly but am going back to the main loop to 1.5". The inlet and outlet tees will still be 2"
    Sean Assam
    could swore i saw a picture somewhere showing positioning of the golf ball cause i'm not quite clear..sorry..my biorythms are off this time of night..or will it be like computers and make sense completely once i have the unit..i would hate to have to return saying cause of failure was a golf fall in the system
    hey..better safe then sorry!
    Ft Lauderdale, Fl
    The Digital manual available on line shows the golf ball, but also states to use this with the old style 1.5"manifold assembly.
    Sean Assam
    Saint Cloud, FL
    Sean,
    You now have put me in a dilemma. Looks like I will have to take up tennis!
    Pat
    Ft Lauderdale, Fl
    Nice. Try to fit the tennis ball in the manifold and see if that works.
    Sean Assam
