Results 1 to 9 of 9
Thread: Preparing for SWCG
    Default Re: Preparing for SWCG
    I also have an Aqualogic and have had exactly the opposite results. I had a leak in my pool so my CYA level was dropping and I found that as soon as my CYA dropped to about 50 I had to crank the output on my cell up to mantain the 3 ppm FC in my pool and the 4-5 ppm FC in my spa. This happened to me twice so it was a repeated effect. Once I bumped the CYA up to about 70-80 ppm my FC levels rose and I had to back off on the output. I currently run my pool at 8% and my spa at 4%. When the CYA levels were lower I has the pool at 20% and the spa at 8%.
    North Florida
    Waterbear...just curious but how long are you running your pump daily?
    Sandy
    8 hours in my pool broken up into 5 hours during the day and 3 in the evenng and 1.5 hours in the spa.
    NY
    I had same concern. I was running AutoPilot on level 2 at about 20-25% with CYA of 40. I am starting to raise my CYA SLOWLY(you can always add, but have to drain pool to decrease) by filling a kneehigh with stabilizer and letting it dissolve in the skimmer. I have it up to 50 now and can run my AutoPilot on level 1 at 30 percent and have a FC of 4 and CC of 0 immediately AFTER big pool parties and the purifier is usually off when I look at the panel so I am happy where it is right now(though I do have some CYA still dissolving as I write this).
    I run my filter for a few hours after the pool is put to bed for the night so the SWG can do it's thing with no added bather load or sun to interfere.
    North Florida
    Smile Re: Preparing for SWCG
    Thanks for all the input. My CYA tested between 30 and 40 with Ben's test kit this AM. I'm out of CYA, so will trot off to the store to have some more on hand. I don't think I'll shoot for 80ppm, even though it's preferred, but I am leaning toward nudging it up a bit, as my chlorine is taxed quite a bit each day from the sun. But I'm still weighing everyone's opinions and deciding where I want my CYA initially.
    PB is here working, but I haven't seen my SWCG as yet (panel is already installed, but not the actual cell). It's threatening to storm, so that installation may not be part of anyone's plans today.
    Sandy
