Page 2 of 6 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 51
Thread: Nature 2?
    Lenny is offline Lifetime Member Thread Analyst Lenny 0
    Wilmington, Delaware
    Default
    I'm not going to use my Nature2 and I might remove the unit at some point, but for now I'm just letting it run without a filter. This won't hurt anything.
    Default
    I keep adding up the costs vs. the benefits and I just see N2 as a waste of money and potentially a problem.
    If you can run the unit without the cartridge without it leaking, then it should have no effect on the pool and you won't need to cut it out of the system.
    But, as I've repeated, $90 per season for a cartridge buys a LOT of bleach!--not to mention it will buy 6 or more quarts of Polyquat--MORE than enough for a season!
    Tinley Park, Illinois, USA.
    Default Nature 2
    All,
    Thank you for your suggestions. I don't think I'm brave enough to cut pvc pipes and such. I will just keep the old filter in (maybe rinse it out). Thanks again!
    Cedar Hill, TX (Dallas)
    Default Re: Nature 2?
    when you open the filter, there's a cartridge. Keep the filter in, just remove the cartridge... nothing to clean. That's what most of us do.
    Heck, I've never even opened the Nature2 Unit... (1 year)
    This post is very much in favor of the Nature2 cartridge. We have used one for the past 5 seasons. Our pool stays crystal clear and I hardly ever have to shock (every 4-6 weeks). All I have to do is use 2 stingy sticks every 5 days. The main reason for wanting less chemicals is my skin. I have psoriasis and very dry skin. This has helped my skin tremendously. If you start reading about how harmful chlorine is to your skin and how it is absorbed in your body you might decide to take an alternatate route and use less. As long as we have a pool I will gladly spend 100.00 at the beginning of the season. Minimal maintenance and more pool time is wonderful.
    Kim
  6. #16
    waterbear's Avatar
    St. Augustine, Fl
    Quote Originally Posted by poolmama63
    Kim
    you might have less chlorine but you are subjecting yourself to both copper and silver so you are not really limiting yourself to exposure to chemicals! Both copper and silver can have negative health effects too. However, I work part time in a pool store and we regularly test for copper (LaMotte colorimeter that supposedly will read .01 ppm copper) and have several customers with Nature2 units. The copper test show no copper to about .03 ppm in the water which makes me wonder if the unit is really doing any thing. Biggest problem I have seen with these units is people let their FC levels drop well below the recommended .5 ppm and that means that the water does not have enough residual sanitizer and is not safe! Clear water is not necessisarily safe to swim in. I tested 3 Nature2 systems yesterday that had NO chlorine in their pools at all. IMHO, this is a bigger concern about whether the water is safe to swim in than how much the cartridge costs to replace or if it is effective. It seems (from my limited experience) to give a false sense of security about pool maintenance and very little margin for error.
  7. #17
    when our water is tested it always comes up with trace amounts of copper, making me think the nature2 is working. Anyway, personally I would prefer to deal with copper than itchy burning skin and red irritated eyes from chlorine.
    All a personal choice I suppose.
    Thanks,
    Kim
  8. #18
    waterbear's Avatar
    St. Augustine, Fl
    the 'itchy burning skin and red irritated eyes" is NOT from a properly maintained chlorine pool. It is caused by chloramines in an improperly maintained pool. Thank you for reinforcing what I said about a false sense of security about pool maintenance in my previous post.
  9. #19
    .warren, michigan
    Wink Re: Nature 2?
    Thanks for all the discussion! I do have a plaster pool so maybe it does help, but I think I'll hold off and see if just good maintenance and the dolphin does the trick! Thanks again!
  10. #20
    When I was at Leslie's Pool Supply last weekend, I checked the price of the Nature 2 filter. It was $105!!!! I paid $90 last year. I'm glad I'm done with that!
    Anna
    24' Above Ground Pool x 54" depth -- 14,000 Gallons (approximately) -- 1 1/2 HP Hayward DE Filter (model EC 45) -- Hayward H150 Gas Heater
