AnnaE,
I got rid of my Natures 2 by cutting the PVC pipes in half right in the center of the hole where the cartridge was mounted. Then I simply used a splice coupling to attach the two halves using PVC glue and primer. I believe there are a couple of different types so your base or mounting bracket may not be the same. I guess you could simply leave the existing cartridge in place and just not replace it.
