Results 1 to 10 of 10
Thread: Codes and A/G Pools
    Downingtown, PA
    Default Re: Codes and A/G Pools
    WTF I need to have a self-closing slider???? I HATE GOVERNMENT! If I am responsible enough for a house shouldn't it be my responsibility to open and close doors?!?! Is that a law in PA?!
    Slider opens up from house to patio with pool. Fence is integrated to yard and does not self-close around pool. I do not have any little kids running around so as long as no one drowns in my pool will my insurance company care?!
    Outside of Philadelphia, PA
    18' x 40' IG - 22K gallons
    Sylvan Gunite Pool (1979)
    Plaster re-done (1997)
    Since your slider opens from WITHIN your house, you're good there, but anything accessible from the yard needs to be protected.
    I don't have a fence around my pool, however, my 5 acres is fenced (horse fencing) but not gated - meaning anybody can get in/out.
    BUT, since the pool is situated in the middle of my 5 acres, this security device http://img.photobucket.com/albums/v2...x4/warning.jpg WILL get them before any pool incidents happen!
    I can't believe your pumps need special plugs and 3 feet of cord maximum - what a joke, we get 20 feet of cord and a regular 3 prong! Like a special plug is going to protect you any better!
    I swear, common sense has pretty much fallen by the wayside in this day and age!
    We have similar codes--a 220 line cannot have a cord longer than 3'--if the pump is hard-wired. Less clear if you have a twist lock. The pump's power hookup cannot be closer than 5 ' to the pool.
    There are do-it-yourself latches and hinges from a company called "MagnaLatch" that puts the control for the latch 5' off the ground--that' code. Here's what my gate looks like--the hinges are self-closing, the latch is self-latching:
    It works EXTREMELY well. I did the install myself--well, I did build the gate and fence, too.
    The latch uses gravity and magnets--no springs.
