Results 1 to 9 of 9
Thread: newbie needs help please
    Jul 2006
    OKLAHOMA
    Default Re: newbie needs help please
    I've received lots of help regarding mustard algae in my pool.
    Check out the thread _newbie with ?'s (mustard algae).
    Several people have been helpful in EXPLAINING things to me! With their help we'll get this stuff G O N E!
    Blessings,
    Debbie in OK
    FOXX IG Vinyl Pool 18 X 36 (installed 2001)
    Pool Volume: 20,655 gallons -- Laars Lite 2 gas heater
    Hayward Pro Series Sand Filter (S-244T) -- Hayward 1.5 HP Pump
    God gave you 86,400 seconds today -- have you used ONE to say THANK YOU?
    Sanford, FL
    Also - I wouldn't run the SWG on "boost" mode - it will cause the cell life to decrease faster than necessary. Just pick up a case of ultra 6% bleach. Test (diluting like posted earlier) and then add bleach (1 gallon 6% strength will raise chlorine 6ppm for every 10,000 gallons) to get the level to 15ppm-20ppm.
    Since you have algae it will "eat up" the chlorine - so you need to test 3x a day and add chlorine (liquid bleach is best) until you get the level between 15-20ppm. Also brush daily and run filter 24/7.
    Completed 8/21/06
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
    Jul 2006
    Pool Clarity Is Much Better To Day. I Am Still Keeping Cl Reading Up For One More Day. How Fast Will The Cl Reading Drop For It To Be Safe To Swim? I Plan On Not Adding Any More Cl After Tonight. I Hope It Will Come Down To About 5- Cl So We Can Have Pool Party Saturday Afternoon. Now My Readins Are:
    PH- 7.8
    TC- 12.0
    FC-10.5
    TOT ALK- 81
    CYA- 35
    THANKS FOR ADVISE. THIS FORUM HAS GREAT ADVISE. NICE TO READ HOW OTHERS SOLVE PROBLEMS.
    BRIAN
    If these numbers are accurate, then you still have 1.5 ppm of CC, which means you need to keep the shock level up at least another day--you want the CC reading to go to 0 before you let it come back down. The Cl will come back down in a day's time, so if you can keep it up 'til Friday morning, then let it drop Friday, then by Saturday it should be fine to swim.
    Jul 2006
    still clear today thanks all.
