except that when you backwash with a DE filter you are flushing out your DE, possibly unnecesarily. When lowering pool levels, do through waste, and backwash only when necessary.
Personally, unless the water level is up to the coping, I let heat and wind lower it for me. Just can't beat free water. Skimmers still work, just not as effectively.
I used my vacuum hose and put the brush end in front of the return jet to get a siphon going to drain water out.
