Results 1 to 10 of 10
Thread: Holding chlorine overnight
    AndieP is offline Registered+ Thread Analyst AndieP 0
    Jul 2006
    Oklahoma
    Question Holding chlorine overnight
    Probably a dumb question but I have been advised to keep the chlorine at shock level until it holds overnight. Does that mean to the exact number?
    Last night when I went to bed I brought the chlorine to 12ppm (cya of 20 or less...added stabilizer a few days ago) This morning at 9:00 my chlorine was 10.5. It also rained last night. All numbers as of this morning....
    FC 10.5
    CC 0
    PH 7.2
    TA 80
    CH 140 (working on raising to 200...concrete/guinite pool)
    CYA waiting to test
    The water is clear...not "sparkling" clear...especially in the deep end but it is clear and a pretty bluish color. Do I need to keep the level at 12ppm throughout the day today and again tonight or can I let it drop to the appropriate number per Best Guess chart?
    Thanks!
    Andrea
    IL.
    Default Re: Holding chlorine overnight
    In normal operation my pool uses 2 ppm of chlorine daily.
    You have no CC, so I'd say you're good to go letting it drop to the appropriate number on Ben's BG chart
    ChuckD is offline Unconfirmed User Weir Watcher ChuckD 0
    Duanesburg, NY
    Quote Originally Posted by AndieP
    FC 10.5
    CC 0
    PH 7.2
    TA 80
    CYA waiting to test
    Thanks!
    Andrea
    That's a pretty small drift. That plus your CC=0 would tell me it's time to let it drop off.
    How much? Need to know your CYA. When did you add it and how?
    C.
    duraleigh Guest
    What has worked well for me in the past is to hold my Cl level at shock value until I was satisfied with the clarity of the water. If your pool consumes additional Cl during this period, you are still clearing. If it does not, there is no harm.
    Running pump 24/7 and backwashing as needed is essential to this clearing process.
    Jul 2006
    Oklahoma
    I added the CYA last Friday. I added it through the skimmer so I haven't backwashed yet. I did give in to the urge to test it before the week is up....and it was only a slight bit clouded at the very top of the tube. The pump has been running 24/7. My kids plus the neighbors kids are begging to swim today...8 kids total....which means I will probably be shocking tonight anyway.
    I was thinking of adding some DE to the filter to see if that would help get the water just a bit clearer.
    Duanesburg, NY
    Quote Originally Posted by duraleigh
    But his CC=0. Wouldn't that indicate he's not consuming any? Further reduction would be more attributable to the sun, no? My attitude is the less chems, the better. In this case, I think I'd be looking for the filter to do it's job at this point.
    C.
    Sanford, FL
    Quote Originally Posted by ChuckD
    C.
    I think the original post said that it dropped overnight.
    But it could have dropped due to the rain?
    Completed 8/21/06
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
    Duanesburg, NY
    Quote Originally Posted by Simmons99
    Maybe he lives above the Arctic Circle!
    I know, I know.... ; )
    He reports a point and a half drop over night. Chlorine's volatile. That's how I attribute what's really an insignificant drop when you also consider all the variables in the testing process.
    C.
