Re: Why not use liquid chlorine instead of bleach ?
Nobody, I repeat NOBODY uses liquid chlorine in a swimming pool. You might think you are, but you are using bleach. Some large commercial pools use chlorine gas, but never liquid. You are not equipped to deal with liquid chlorine. Believe me, I am a chemical engineer and used to work in a chlorine / caustic soda production facility. Liquid chlorine does not exist in nature, and the only way to get it is to compress and deep chill to liquefy it. It will only remain a liquid under pressure and low temperature. When exposed to normal pressures and temperatures it will quickly flash off to a greenish yellow gas. If you were hanging around liquid chlorine without a respirator you would most likely now be in a hospital with chemical pneumonia, unless you were already dead.
