Results 1 to 10 of 29
Thread: For those of you using Bleach...
    Howell, Michigan
    Default Re: For those of you using Bleach...
    Excellent thread,
    <30 CYA, 2 - 3 ppm / day
    graciec is offline Registered+ Thread Analyst graciec 0
    Thumbs up Re: For those of you using Bleach...
    Dr Spike...this is off topic...So excited to see you have a dome!!!!! how do you like your dome?
    We are in Michigan and I want one!!!!!! If they move this question off this board, can I ask you on the off topic board??
    Tennessee
    Full sun 8 hours day. Loose about 2 to 3 ppm each day. Add 1 qt one day 2 qt the next. CYA 35 to 40 ppm.
    jmjbj_h Guest
    My CYA is 45 and I am losing about 2-3ppm a day. Full sun and medium/heavy bather load. Mostly several kids under 6. Can anyone say...toilet? I put in a bottle a day
    Joe
    Sun Prairie, WI
    Quote Originally Posted by graciec
    Graciec,
    I do like the dome, we should move the dome discussion to the off topic forum and not hijack this thread.
    ~Dr. Spike
    Pool: IG vinyl, heated, fully enclosed (dome)
    Shape: Grecian (rectangular)
    Size: 20'W x 40'L
    Depth: 4' / 8'
    Filter: Sand w/DE added
    Other: 6' Diving Board
    Maintenance: BBB! Ben's PS234 kit! Manual vacuum, brush, and Pool Buster Max CG Gold
    The answer to your question is a function of both CYA and FC (total free chlorine) levels since twice the chlorine level loses about twice the amount of chlorine per day. I now have around 15 CYA and 2-3 ppm FC and lose about 0.5 ppm per day. The pool is normally covered and is open to sunlight (it's an outdoor pool) about 14 hours per week. I used to have more CYA, but had more chlorine and the rate of loss was about the same.
    Barstow, CA.
    Holds overnight, uses ~2ppm during our very hot & very sunny days. CYA ~50, water temps 90-94.
    12,000 gallon Hawaiian Fiberglass
    CFR 100 Jacuzzi Cartridge
    Fallon, NV
    Interesting thread. I was thinking just the other day when I was adding additional bleach, "mann I sure add a lot of bleach each day. I wonder if I am in the normal usage range of bleach". From these posts I see that I am not alone. I love the BBB method after coming from the 'dark side' of Baq...But for me it's more of a B method, as I never have to raise my PH or ALK. It's more of a BAW (Bleach, Acid and Water). Our pool is 26K gal. inground, plaster. Outdoor, full sun in the middle of the Nevada desert. A few leaves, sand and light bather loads. Stays covered at night, unless the water temp is to high and we want to cool it off. CYA runs in the range of 20-30. I add 10 cups of liquid belach in the morning when the filter first comes on. The CL is 1.5 to 2 PPM. I then check the CL and PH in late afternoon, 6ish or so, and it's normally down to .5 PPM. PH runs in the range of 7.2 - 7.5. I then add another 10 cups of bleach and cover the pool. Filter runs for an additional 3-4 hours after last bleach is added. Then repeat the cycle next day.
    Scott,
    Berwyn, PA
    Quote Originally Posted by chem geek
    If this is the case, then perhaps we should all be reporting the percentage drop in PPM that we experience each day, rather than the PPM itself?
    I wouldn't have thought it was quite that linear - certainly chlorine loss after shocking seems much faster (even in percentage terms) than regular chlorine loss.
    23' x 41' 32k gal plaster circa 1991, 600 gal spa with overflow
    Ultraflow pumps, Titan SS filter, Sta-Rite heater, Polaris 180
    Homegrown X-10 automation -- filter, cleaner, valves, lights, chlorination
    Central Texas
    15,000 gallon, IG, Plaster, CYA ~ 30ppm
    Loses about 2 ppm per day, in full sun 10 AM - 6 PM
    Light bather load, minimal debris currently
