Thread: CYA ? and pic of finished product
    Default Re: CYA ? and pic of finished product
    Excellent work!
    2 on the chlorinator may be a littel low, if your Chlorine reading keeps dropping then I would recommend slowly raising the input until you are at a point where your Chlorine reads the same. However, that said, low CYA will let your chlorine burn off faster.
    I would get the CYA up to the right level, then just add bleach in the right amounts (you'll figure that one out easily enough) as you need to. Rememeber that the hotter it gets, the more frequently you will need to add bleach, don't put this task off til tomorrow, it will bite you you know where.
    MaryLee is offline Registered+ Thread Analyst MaryLee 0
    Southern New Hampshire
    You already gotten your answers, but I just want to say your pool and deck look beautiful!! Great job!!
    18 X 40 IG Vinyl
    3 1/2' ft to 8' deep
    Pentair DE Filter
    400K BTU Pentair Minimax heater
  1. I finished pool chart and liked on FB
    By michael3 in forum General Interest
    Last Post: 05-29-2013, 05:39 PM
  2. Are we finished?
    By KatieD in forum Chlorine Alternatives: UV, Ozone, Baquacil (PHMB), etc
    Last Post: 09-04-2006, 12:04 PM
  3. After testing is finished
    By VOLDADDY in forum DPD-FAS based testing
    Last Post: 07-15-2006, 04:34 PM
  4. So sad, a leak in my just finished pool ...???
    By ValAZ in forum In-Ground Pool Construction and Repair
    Last Post: 04-17-2006, 11:34 PM
