Closed Thread
Thread: swimming machines...
    Green Bay, WI
    Default
    I have the badu swim jet in our 13x26 indoor. It was the larger of the 2 at the time. It is plumbed with 6 inch lines to the 4 hp motor and back to the jet. It took me about a week or two to get used to swimming against the jet. At first I was worried it wasn't a "fast" enough flow, but as you get used to it it is more then enough. While just about any good swimmer could swim right up to it, to stay at 5 feet back for even 5 minutes is a chore. Sort of like sprinting vs jogging speeds.
    The only real trick for me was to stay centered on the jet, fortunately I have a center tile line on the bottom that helps out a lot. I would really recommend it to anyone who wants to swim in place. I did try the foot straps and other non-pump methods and you just don’t get the same feeling.
    Default Re: swimming machines...
    Thanks for the feedback!
    I figured the significant thing about one of these would be the lack of the turn-kick-drift, so basically no rest. Pretty much like learning to swim open water - constant. Any problems with the Badu?
    I am trying to figure out if a jet or prop/fan design would be more 'natural' feeling...
    Green Bay, WI
    We did try both the jet and the fan types before we built ours. The prop we tried seemed slower, but wider while the jet was faster but you had to stay centered a bit more.
    We haven’t had any problems with the jet, although the kids like to aim both jets to the far side and make a huge circular lazy river. It also comes in handy for adding chemicals or aerating the water after shocking.
Closed Thread
