Re: before i kill myself with stabilizer
by the way..riddle me this..if you're not supposed to mix chemicals, what's the process then for stabilizing> bleach..
in other words..i'll test my cya when i get home..if it's good, it's good..if it's low..i will do the sock thing or mix in water and put in pool..how long before i can add chlorine after that?
tanks again.
