Results 1 to 10 of 14
Thread: Switching to Bleach?
    Jan 2006
    Atlanta
    Default Switching to Bleach?
    OK after reading of all the virtues of plain old regular bleach I think I'm ready to try it.
    But How?
    Right now I have an Automatic Chlorinator That I stuff with 3 inch tabs about once per week. My pump runs 7AM - 7PM 7days per week.
    If I go regular chlorine how much do I put in and when should I run my pump.
    Pool gets minimal use on weekends since it is just for my wife and I.
    It is a 16x32 IG vinyl woth 8ft walkout steps.
    CToon is offline Registered+ Thread Analyst CToon 0
    Elkins Park,Pa
    Default Re: Switching to Bleach?
    Hi Jim ,
    Have you tested for your CYA level ? It is important to know so you can figure out where you need to keep your CL levels at.
    Have you downloaded MWsmiths Bleach Calculator ? It will tell you how much bleach you need to achieve CL levels
    One caution about rellying on the pucks to chlorinate the pool . Pucks can quickly raise the CYA in the pool to a point it becomes a problem. trust me I know
    Jan 2006
    Atlanta
    Thanks for the quick reply.
    I found that site bit I don't know how to use it. The length of my pool is 32ft, the Chlorine Strength is 6 I gather and the desired PPM is 5.
    I don't know what the quantity should be.
    My CYA was high but I've been adding more water lately in an effort to get it down.
    Any examples of how this is calculated?
    Jan 2006
    Atlanta
    I guess L means Litres not length so I need to find a gallon to litre conversion chart
    Elkins Park,Pa
    to change the calculator to Gallons go to More Calcs in upper left , go to settings ,click imperial (its u.s gallons ) you can also put in pool volume and bleach values.. save and close
    if you dont know the pool volume , the calculator has a thing for that too. bleach strenght is almost always on the bottle ( generic store brand dont always)
    oops prh beat me too it
    fcfrey is offline ** No working email address ** Thread Analyst fcfrey 0
    Central PA USA
    [QUOTE=CToon]to change the calculator to Gallons go to More Calcs in upper left , go to settings ,click imperial (its u.s gallons ) you can also put in pool volume and bleach values.. save and close
    You should know --- an Imperial Gallon =1.20095 US Gallon ---- THEY ARE NOT THE SAME!!!!
    Rehoboth, MA
    Hi Jim,
    First, go to More Calcs and click on Pool Volume. Put in the dimensions of your pool in the box that fits the pool description (rectangular etc). The settings tab in More Calcs lets you choose between litres and gallons.
    Now you can go back in the main screen and enter your pool volume and your bleach strength. In the Chlorine section of the forum, you will find Ben's Best Guess chart for figuring out the chlorine level you need based on your CYA level. Find your target chlorine level and look at your free chlorine test reading to see how much you need to raise your chlorine level up (in ppm). Put this number in the program and hit calculate and it will tell you how much bleach you will need to add to your pool to make that happen. Hope this helps.
    Peter
    Jan 2006
    Atlanta
    Thanks Guys
    I think I got the volume right. So we just pour the Liquid Bleach in the skimmer in the evening after everyone has stopped using the pool. Then run my pump all night long.
    From other threads I've read it seems Clorox is 6% and that's what I've used in the calc.
    Rehoboth, MA
    Jim,
    You can either pour the bleach in the skimmer, in the pool in front of the return jet or dribble around the perimeter of your pool. In any case you shouldn't need to run your pump for more than an hour or so afterward to circulate the chlorine - you don't need to run it all night (unless you want to).
    Ultra bleach is usually 6%, and regular bleach is usually 5.25%. There are also some bleaches out there that are only 3% so you should check the label - it should tell you somewhere on there.
    Peter
