Results 1 to 10 of 14
Thread: Switching to Bleach?
    Rehoboth, MA
    Default Re: Switching to Bleach?
    Jim,
    You can either pour the bleach in the skimmer, in the pool in front of the return jet or dribble around the perimeter of your pool. In any case you shouldn't need to run your pump for more than an hour or so afterward to circulate the chlorine - you don't need to run it all night (unless you want to).
    Ultra bleach is usually 6%, and regular bleach is usually 5.25%. There are also some bleaches out there that are only 3% so you should check the label - it should tell you somewhere on there.
    Peter
    Jan 2006
    Atlanta
    Thanks Peter
    I currently run my pump from 7AM-7PM and my water has been crystal clear.
    I was thinking that changing it to 7PM-7AM is better since that would be the time I am adding the Clorox.
    Does that make sense?
  1. switching to saltwater
    By mrsmatthews in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-08-2013, 06:36 PM
  2. Switching from Ionization need Help
    By wil804 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-09-2012, 10:14 AM
  3. Switching Pool to SWG
    By jl1965 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-12-2008, 10:51 PM
  4. Switching to BBB. What do I do with these numbers?
    By thewayne in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-27-2006, 09:24 AM
  5. switching to bleach...one more question
    By mspool in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-12-2006, 03:49 PM
