Thread: Plaster pool has a 'natural' pH maybe?
    Central Texas
    Default Re: Plaster pool has a 'natural' pH maybe? Another possible cause?
    Is it also possible that the interaction with the CO2 in the air is causing the water to seek a 'natural' pH based on the alkalinity? If so, it may be advantagous to lower the alkalinity even more if I can get the pH to stabilize at a lower level than 7.6.
    In an aquarium, the lowest alkalinity recommended is about 60ppm in order to prevent a pH 'crash' - a sudden drop into acidity. Is there a downside to run it that low in a pool?
    Sanford, FL
    7.6 is still in the normal range of PH levels. I would say to let it stay at 7.6 if it wants to drift there instead of trying to keep it down.
    Completed 8/21/06
    Spa with spillway
    250K BTU gas heater (for spa)
    SWCG - Aqua Rite
