Results 1 to 10 of 14
Thread: Can a filter hose be fixed?
    Attleboro, MA.
    Default Can a filter hose be fixed?
    I have a hose going from my filter to return. It's the regular plastic type hose. 6' in length, 1 1/2". There is a pin hole leaking in the hose. I did buy a replacement hose but was wondering if this hose with the pinhole in it can be fixed?
    I just bought the hose at the end of the season, think my DH hit it with the weedwacker.
    Default Re: Can a filter hose be fixed?
    Hi, I fix everything with Duct tape. It's just a bandaid though, best bet is to replace it.
    Later, Dennis
    Not to disagree with Denis, but the duct tape will only slow the leak. Sure, there are things that can patch/ plug the leak, but getting a new hose is the way to go. BTW, tell DH to be a little more careful around the pool equipment
    It's been a very long, really hot day and I was just being silly. There really is no way to patch a pool hose, that I know of. Just replace it. That's two votes to replace.
    Stay wet, Dennis
    Tredge is offline Registered+ Thread Analyst Tredge 0
    Wisconsin
    I tried Duck tape when mine sprung a pinhole leak.....didnt work. No combination of glue and tape would hold it.
    Try Gorilla Tape from the hardware store....I'd try it for kicks just to see if it would last.
    Some people have hobbies.....I have a pool.
    Tennessee
    If it is the flex pvc why not cut the hose at the hole and put a straight coupling there.
    I tried duck tape but the hole quacked open further!
    (another fowl attempt at humor).
    Tennessee
    CarlD
    (groan) ...
    As bad as my crappy humor but more class!
    http://www.poolforum.com/pf2/showthr...5895#post25895
    Except I cant send you to your room.
    I fix any leak in plastic with one of two methods, both of which supply the same end result.
    1. Torch and heated knife
    2. Soldering iron.
    Sometimes a little extra plastic is needed for your welding bead, try to find the same plastic for your welding. So far it has worked on every leak I have had to seal.
    It works awesome on cracked solar panels and you do not lose that particular vein in your panel, so in turn, the panel does not lose efficiency.
    Jacksonville, Florida
    better off just hard plumbing it in with PVC, eliminate (well, almost) the possibility of a trimmer accident again...
    parts are fairly cheap, and will last a lifetime (treated properly)
    my 2 cents...
    good luck with it
    in the residential and commercial water treatment industry, if you don't have some type of system, get one !!!
    '' common sense aint so common"
    "to be, or not to be... without beer, that is the question"
    Our "easy set" (yeah right, 6 days later) and still working
    but, it is a start to a wonderfull "pool owner lifestyle"
    upgrade is already planned... so don't laugh at it, its our first, and not the last!
    http://pg.photos.yahoo.com/ph/dj71da...?.dir=/562fre2
  1. New Member/Hose from Pump to filter
    By jrg1372 in forum Above-Ground Pool Construction & Repair
    Last Post: 09-03-2012, 03:56 AM
  2. Filter Connection Hose
    By techguy9707 in forum Above-Ground Pool Construction & Repair
    Last Post: 05-22-2011, 03:39 PM
  3. DE Filter Problem - Fixed
    By wa2asb in forum In-Ground Pool Construction and Repair
    Last Post: 06-24-2010, 06:37 PM
  4. Running pvc from sand filter to hose to pump?
    By mjs31 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-23-2007, 10:56 PM
  5. Hose from filter to return keeps blowing off
    By nicole12 in forum Above-Ground Pool Construction & Repair
    Last Post: 08-10-2006, 03:17 PM
