Results 1 to 10 of 14
Thread: Can a filter hose be fixed?
    Attleboro, MA.
    Default Can a filter hose be fixed?
    I have a hose going from my filter to return. It's the regular plastic type hose. 6' in length, 1 1/2". There is a pin hole leaking in the hose. I did buy a replacement hose but was wondering if this hose with the pinhole in it can be fixed?
    I just bought the hose at the end of the season, think my DH hit it with the weedwacker.
    Default Re: Can a filter hose be fixed?
    Hi, I fix everything with Duct tape. It's just a bandaid though, best bet is to replace it.
    Later, Dennis
    Not to disagree with Denis, but the duct tape will only slow the leak. Sure, there are things that can patch/ plug the leak, but getting a new hose is the way to go. BTW, tell DH to be a little more careful around the pool equipment
    It's been a very long, really hot day and I was just being silly. There really is no way to patch a pool hose, that I know of. Just replace it. That's two votes to replace.
    Stay wet, Dennis
    Tredge is offline Registered+ Thread Analyst Tredge 0
    Wisconsin
    I tried Duck tape when mine sprung a pinhole leak.....didnt work. No combination of glue and tape would hold it.
    Try Gorilla Tape from the hardware store....I'd try it for kicks just to see if it would last.
    Some people have hobbies.....I have a pool.
    Tennessee
    If it is the flex pvc why not cut the hose at the hole and put a straight coupling there.
  1. New Member/Hose from Pump to filter
    By jrg1372 in forum Above-Ground Pool Construction & Repair
    Last Post: 09-03-2012, 03:56 AM
  2. Filter Connection Hose
    By techguy9707 in forum Above-Ground Pool Construction & Repair
    Last Post: 05-22-2011, 03:39 PM
  3. DE Filter Problem - Fixed
    By wa2asb in forum In-Ground Pool Construction and Repair
    Last Post: 06-24-2010, 06:37 PM
  4. Running pvc from sand filter to hose to pump?
    By mjs31 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-23-2007, 10:56 PM
  5. Hose from filter to return keeps blowing off
    By nicole12 in forum Above-Ground Pool Construction & Repair
    Last Post: 08-10-2006, 03:17 PM
