Thread: help with chlorine
    CToon is offline Registered+ Thread Analyst CToon 0
    Elkins Park,Pa
    Default Re: help with chlorine
    For the 5 way kit from walmart , if you fill the test cylinder up to the line and added 5 drops and it didnt register , you need to add chlorine.
    Look for MWsmiths Bleach Calculator . It will tell you how much bleach you need for your size pool
    fcfrey is offline ** No working email address ** Thread Analyst fcfrey 0
    Central PA USA
    I hope you meant Borax (20 mule team) and NOT Boraxo (hand soap).
