Thread: help with chlorine
    Default Re: help with chlorine
    Quote Originally Posted by ccc
    I cant get chlorine to regester Ph is 6.9 I put boraxo in to bring it up. Alk is at about 80. Iuse 6way tester from Walmart
    I hope you didn't use boraxo....that is a hand soap. You need to use Borax (20 mule team in the green box)
    Have you put any chlorine into the water? How much? HOwmany gallons is your pool?
    Please post a complete set of test results, how many gallons your pool is, and whether it is vinyl, fiberglass, or plaster.
    gerri is offline Registered+ Thread Analyst gerri 0
    Jul 2006
    Upstate, SC
    I think the 6 way is the test strip. I have some of those from WalMart but since I found this site I upgraded to the drops kit. It's amazing how different your readings are with the strip and drops. I won't trust a strip test again.
