Results 1 to 10 of 17
Thread: stupid me
    Default stupid me
    I think I broke my pool. I did not know how to clean the filter. (I do now) ( you know what I am about to say, dont you) Please dont laugh too hard. Anyhow, I unscrewed the top. Water went flying everywhere. I had to call hubby from work, and he came home to try to fix it. Well I got the plugs on and the water stopped spraying. But now I cant get the O ring back on top of the pump. I did the best I could, reset the strainers and it still was leaking like crazy. So I put the plugs back in. What do I do now?
    Thanks in advanced. I am upset because I cant run the pump, cant put in the chlorine, and do not want my pool green.
    Default Re: stupid me
    Hi, I would love to help you out but more info is needed.
    Are you talking about the lint basket in front of the pump, and if so what kind of pump?
    Or are you talking about the top to maybe a cartridge filter?
    They both have o-rings and both leak a lot of water if the skimmer and return are not blocked.
    A Photo would be the quickest way to get help.
    Later, Dennis
    cheap intex above ground. No skimmer basket with it, just the jet for in and one for out. Ok ..i put plugs on them so the pump would stop leaking. the O ring is like what I call the hat of the pump. Where the cartridge filter goes. right below the air release button....
    Ok, now that I know it's an Intex I can help.
    Now that the lines are plugged, pour the water out of the filter. Dry out the o-ring's slot, and the ring. If you have teflon o-ring lube, that's better.
    Next you need to force the o-ring into its slot all the way. Don't use anything metal or you'll tear it--a thumb is best. You need to work the o-ring slowly into slot all the way around--it may be a little big (a real pain) so you'll have to sort of distibute it around the whole slot. Then you can put in the filter and put the cover back on, tightening it down. Then pull the plugs and see if it's sealed. Remember to put the spacer on the cartridge (if they still use them) and situate the cartridge correctly on the pipe at the bottom of the chamber.
    At least I think that's how it all works--it's been several years since I opened my Intex pump--it's retired 4 years now.
    Jul 2006
    Hot, Dry Texas!
    I think Carl pretty much covered it, but you sure brought back alot of memories of my intex pool... for some reason I really don't miss that thing at all!!!
    I don't miss the filter, but the pool served us well for 3 seasons and doesn't owe us a dime, despite the fact that it now costs about 1/3 of what it did then.
