Results 1 to 10 of 17
Thread: stupid me
    Default Re: stupid me
    Hi, I would love to help you out but more info is needed.
    Are you talking about the lint basket in front of the pump, and if so what kind of pump?
    Or are you talking about the top to maybe a cartridge filter?
    They both have o-rings and both leak a lot of water if the skimmer and return are not blocked.
    A Photo would be the quickest way to get help.
    Later, Dennis
    cheap intex above ground. No skimmer basket with it, just the jet for in and one for out. Ok ..i put plugs on them so the pump would stop leaking. the O ring is like what I call the hat of the pump. Where the cartridge filter goes. right below the air release button....
    Ok, now that I know it's an Intex I can help.
    Now that the lines are plugged, pour the water out of the filter. Dry out the o-ring's slot, and the ring. If you have teflon o-ring lube, that's better.
    Next you need to force the o-ring into its slot all the way. Don't use anything metal or you'll tear it--a thumb is best. You need to work the o-ring slowly into slot all the way around--it may be a little big (a real pain) so you'll have to sort of distibute it around the whole slot. Then you can put in the filter and put the cover back on, tightening it down. Then pull the plugs and see if it's sealed. Remember to put the spacer on the cartridge (if they still use them) and situate the cartridge correctly on the pipe at the bottom of the chamber.
    At least I think that's how it all works--it's been several years since I opened my Intex pump--it's retired 4 years now.
    Jul 2006
    Hot, Dry Texas!
    I think Carl pretty much covered it, but you sure brought back alot of memories of my intex pool... for some reason I really don't miss that thing at all!!!
    I don't miss the filter, but the pool served us well for 3 seasons and doesn't owe us a dime, despite the fact that it now costs about 1/3 of what it did then.
    Thanks y'all. I know one day I will laugh at this. Ha ha. Right now I just want my pool fixed. LOL. I just had all the water right, just warming up to where I was enjoying it, just got the ph and chlorine correct, and just was adding the stablizer. UGH.
    I have done dumb things before, but this has to be one of the dumbest. I will post when I get it fixed. I also need to add another inch or so of water, so back to the drawing board on chemicals and temp. Ugh ugh ugh. Thanks again.
    One last thing.... Don't forget use the top twist valve to let get the air out to the filter before you run it again.
    Also releasing the presser from the top twist valve before unscrewing the whole top makes it easier to twist and keeps your feet dry. That way you will know if your drain plugs are in.
    Have fun.
  1. Did something stupid
    By Jacob99 in forum Pool Equipment & Operations
    Last Post: 08-14-2012, 12:00 AM
  2. Stupid Question...
    By Ken S in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-10-2010, 10:27 PM
  3. Stupid question?
    By Mojo1 in forum Pool Cleaning: Manual or Automatic
    Last Post: 04-06-2009, 01:34 AM
  4. Stupid mistake...
    By mkelley in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-04-2008, 06:29 PM
  5. Stupid, STUPID ? and aerating...
    By poolmom06 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-03-2006, 11:12 AM
