Re: Just opened new pool/ first test #
Hi, Chris,
First of all, I'm a little puzzled by your cloudiness. Nothing I can see in your test results would indicate a cause. I'd suggest you bring a few things in to range and, running the pump 24/7, that'll perhaps clear it up.
1. Sounds like you're already on it but get your pH stable around 7.2 - 7.6
2. Next, I'd bring up your Alk.....it's VERY low. Use bleachcalc to figure how much baking soda will get you around 90 to start.
I really don't see how those two items are causing cloudy water but they really need attention.....get them into range, run your pump, keep the pucks in there (for now) and I think things will improve soon. Post back with new results in a day or so and describe your water's appearance.
Congrats on your new pool!
