Re: Washed out!
This does not sound too serious, unless the reason it has washed out is a leak in the liner or something. Take some sand and pile it back in there, you can use a sledge hammer like a battering ram to pack it back in there, then pile dirt around the outer edge to seal it in and pack it down too.
Ultimately, I have to ask though, why do you suppose the sand washed out? What caused it?
Re: Washed out!
The ground around the area is dry so I went into the pool and looked at the liner and there is a patch just above the cove. I am assuming this was the cause of the wash out.
If I understand you right, I can just take some sand, force this back under the liner, and pack it in tight? I don’t need to lift the liner up at all to replace the sand?
Thanks for your help
Re: Washed out!
No, just get it back in there really good. Is the patch holding?
Re: Washed out!
Yes, the patch seems to be holding fine. I don’t see any signs of wetness on the ground and I am not losing any water. I Did the bucket test to make sure.
I appreciate your help in this matter.
Thanks.
