Closed Thread
Thread: Washed out!
    Default Re: Washed out!
    The ground around the area is dry so I went into the pool and looked at the liner and there is a patch just above the cove. I am assuming this was the cause of the wash out.
    If I understand you right, I can just take some sand, force this back under the liner, and pack it in tight? I don’t need to lift the liner up at all to replace the sand?
    Thanks for your help
    Morris, IL
    No, just get it back in there really good. Is the patch holding?
    Yes, the patch seems to be holding fine. I don’t see any signs of wetness on the ground and I am not losing any water. I Did the bucket test to make sure.
    I appreciate your help in this matter.
    Thanks.
Closed Thread
